Ga door naar hoofdinhoud
External storage options by Seagate, usually connected by USB, available in many storage sizes and form factors.
Can’t find screw bit for External HD
Can’t figure out the screw bit needed for this and that’s after going through my bits in my pro tech tool kit.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
That looks like a Torx TR6, TR8 or TR10 screw. There are two versions of Torx these with a pin in the middle is the security version (TR)
By chance is this a five lobe screw? Your image is not very clear, then that would be a 5-Point Tamper Resistant Star Bit
Compatible with both T8 and T8 Security fasteners (TR8). Precision fixed blade screwdriver engineered by iFixit. Afbeelding
Product
TR8 Torx Security Screwdriver
$5.99
Compatible with both T10 and T10 Security fasteners (TR10). Swivel top handle with precision tip driver. Afbeelding
Product
TR10 Torx Security Screwdriver
$5.99
Product
TR6 Torx Security Screwdriver
$5.99
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Typical T6 or T8 security Torx screw.
door
Hi @danj ,
Here’s a better view of it to confirm
Click on image to make it even bigger ;-)
Cheers
Score 3
6 opmerkingen:
@jayeff - Ha! You've got younger eye's ;-}
door
So since that’s a five ‘star’ what’s the exact bit name I would need?
door
@gingersenpai
See the link regarding the 5 point tamper resistant star bit in the above answer
door
@jayeff Thank you.
door
Hi @danj,
Don't know about that. I'm pushing 70 this year ;-)
Cheers
door
1 commentaar meer tonen
Voeg je antwoord toe
Scott Vogel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 15
Altijd: 290
