Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597 Vragen Bekijk alle
Hardware Update Question for a mid 2012 MacBook Pro
Hi There,
I am a novice who, by ordering and learning from ifixit, have been able to keep our old macs alive and well. I have a new question.
I have a mid 2012 15 inch macbook pro. I can see I have 2 memory slots, each of which accepts a 1600 MHz DDR3 memory module.
Currently there is 8Gb installed as 2 times 4Gb.
I am unsure if the article above means I can now install 8Gb in each memory slot making the total ram into 16Gb or whether I am now at full capacity.
I hope you can help clear this up. Thanks for the work you do to help us save the environment.
Cliff
Queensland, Australia
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
RAM Type:PC3-12800 DDR3LMin. RAM Speed:1600 MHz
Standard RAM:4 GB Maximum RAM:16 GB*
To upgrade you will need to pull one or both of the 4GB sticks and replace with 8 GB sticks. You can mix the RAM size for 12GB with one 8GB stick or replace both for 16GB.
Here’s how to do it:
MacBook Pro 15" Unibody mid 2012 Vervanging van de RAM
Was dit antwoord nuttig?
Score 2
32 GB RAM UPGRADE  on a MacBook Pro, Mid-2012
THESE ARE THE ORIGINAL SPECS:
This 15-inch Mid-2012/USB 3.0 MacBook Pro 9,1 features a 22 nm “Ivy Bridge” 2.6 GHz Intel “Core i7” processor (3720QM), with four independent processor “cores” on a single silicon chip, a 6 MB shared level 3 cache, 8 GB of 1600 MHz DDR3L SDRAM (PC3-12800) installed in pairs (two 4 GB modules), a 750 GB Serial ATA (5400 RPM) hard drive, an 8X DL “SuperDrive,” dual graphics processors -- an NVIDIA GeForce GT 650M with 1 GB of dedicated GDDR5 memory and an “integrated” Intel HD Graphics 4000 graphics processor that shares system memory, as well as an integrated 720p FaceTime HD webcam.
After purchasing it, I put in 16 GB, and it works great. From experience, it can significantly improve my speed when running concurrent tasks.
Can anyone tell me if there are any compatibility issues with this upgrade?
I have yet to be negatively forewarned; specs show it will handle 32 GB, which I will purchase if I don’t hear anything from you all!
intel SPECS:
/Product  CollectionLegacy
Intel® Core™ Processors
Code Name
Products formerly Ivy Bridge
Vertical Segment
Mobile
Processor Number
i7-3720QM
Lithography
22 nm
CPU Specifications
Total Cores
4
Total Threads
8
Max Turbo Frequency
3.60 GHz
Intel® Turbo Boost Technology 2.0 Frequency
3.60 GHz
Processor Base Frequency
2.60 GHz
Cache
6 MB Intel® Smart Cache
Bus Speed
5 GT/s
TDP
45 W
Supplemental Information
Marketing Status
Discontinued
Launch Date
Q2’12
Servicing Status
End of Servicing Lifetime
End of Servicing Updates Date
Tuesday, December 31, 2019
Embedded Options Available
No
Datasheet
View now
Memory Specifications
Max Memory Size (dependent on memory type)
32 GB
Memory Types
DDR3/L/-RS 1333/1600
Max # of Memory Channels
2
Max Memory Bandwidth
25.6 GB/s
ECC Memory Supported ‡ No
Voeg je antwoord toe
Cliff zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 39
