Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De draadloze Xbox One-controller werd geïntroduceerd in 2016 bij de lancering van de Xbox One S en voegt Bluetooth-ondersteuning toe voor Windows 10/11. Deze controller lost veel van de ontwerpfouten op die in de Model 1537/1697-controllers werden gevonden en is veel betrouwbaarder. Deze controller is vervangen door de verbeterde Model 1914-controller.
Controller buttons not working
When I play certain games such as the sims 4, the left thumb stick constantly moves but in other games is fine . Also whilst playing the sims the d pad doesn't work at all? But in other games is perfectly fine?
Is dit een goede vraag?
2 opmerkingen:
connecting to a computer? or on the xbox console?
door
Connecting to my xbox 1
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
The fact that it only happens in Sims 4, and the D-pad works in other games, is a big clue — a broken D-pad usually fails everywhere, not in one game. So first check Sims 4 itself: reset its controls to default, turn off any mods or custom control schemes, and check whether the game is using a different controller profile or has camera controls mapped to the stick.
Also, with the controller on a table and untouched, watch whether the left stick creeps on its own in other games. If it only creeps in Sims 4, that again points to that game's settings.
To check whether the controller itself is sending those inputs,test your controller online for free and press each D-pad direction and move the left stick slowly. If every press registers cleanly there, the hardware is sending the right signals and the fault is almost certainly in Sims 4's settings, mods, or profile. If a direction misses or the stick drifts untouched, clean around the stick, check for a stuck button, and test wired versus Bluetooth before opening it.
Disclosure: I run this free tester.
Was dit antwoord nuttig?
Voeg je antwoord toe
[deleted] zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 208
