Ga door naar hoofdinhoud
Uitgekomen op 4 november 2017. Model A1865, A1901. Verkrijgbaar als GSM of CDMA / 64 of 256 GB / Zilver of Space Gray. (Uitgesproken als "iPhone 10".)
1200 Vragen Bekijk alle
How come the replacement screen I bought doesnt match my phone?
I have an iphone x and was trying to replace my screen. On the left is the screen i received - it seems to have support brackets all the way around and does not fit my phone. However, my original screen does not have these brackets and is flat all the way around. Does anyone know what my problem is + why my iphone x seems to be different than the normal one?
Update (05/30/2021)
if this is the correct screen…how are these tabs supposed to fit into what looks to be a flat bracket covering?
Update (05/30/2021)
also comparing other iphones online, mine looks to be a bit different with this top area as well? anyone know whats going on here?
Is dit een goede vraag?
1 Opmerking
How did you remove the old bezel from the phone?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I think it snap of of the original screen and sit stuck in the housing, take a look if the part is still left in the housing and take it out.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
You’ve torn the bezel off the screen, normally it doesn’t happen, usually it happens with phones that are heavily corroded by sweat, or you’ve got a non-original screen to begin with, the bezel wasn’t attached to the screen securely on those screens.
Score 2
2 opmerkingen:
@Spencer Lott you still have the bezel on the phone, pull it off.
door
you are the man
door
Voeg je antwoord toe
Spencer Lott zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 25
Altijd: 453
