Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
1.5 Core Solo-, 1.66- of 1.83-Core Duo- of 1.83- of 2 GHz Core 2 Duo-processor. Dit dekt de eerste op Intel gebaseerde Mac mini-modellen van begin 2006 tot medio 2007.
PRAM Battery Not Working
A Mac Mini I have wasn’t saving the date and time/wifi so I ordered a new PRAM battery. I put it in but the date and time/wifi still isn’t being saved. I flipped it around but the same issue occurred. I have pushed the metal fingers as close to the battery as I can, yet it still wiggles a little bit, so maybe that’s why? I tried it on another A1176 I have and the same problem.
Is dit een goede vraag?
5 opmerkingen:
What is the batter markings?
It sounds like you either got the wrong one or its bad
door Deel
@danj I bought the ones that were in the guide
door Deel
@Jordan Baron - What is the batteries markings?
door Deel
@danj Energizer CR2032
door Deel
@Jordan Baron - Well, that's the correct battery, why I pressed was there is a thinner battery which is only 1.5v.
Your comment "yet it still wiggles a little bit" made me question if that was your issue. At this point your logic board socket maybe damaged as the battery is firmly held.
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Before you return what sounds like a bad battery, open up the date and time preferences and make sure you have the “set date and time automatically” checked.
Was dit antwoord nuttig?
Voeg je antwoord toe
Jordan Baron zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 438
