Ga door naar hoofdinhoud
De Xbox 360 is de tweede spelcomputer die Microsoft maakte en werd uitgebracht op 22 november 2005.
Optical drive will not open
I followed the repair guide for this issue, though the optical drive still will not open when the button is pushed. I can hear it trying and was able to get it to work once with the help of a spudger. Is there a common issue that I may be overlooking? I cleaned the rails, as well as the rubber belt that controls the movement, but nothing seems to be working.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Rubber belt get old and take a set especially if not used for a while. Cleaning doesn't help unless they are still soft.
Start by replacing the belt. If that doesn't work, there may be cracked plastic gears slipping on their shaft. Plastic does that when it gets old.
Was dit antwoord nuttig?
Score 1
I have this problem as well what I did was to hold down the button.
Voeg je antwoord toe
TYLER GOODWIN zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 168
