Ga door naar hoofdinhoud
My headphone jack isnt working
the left side in the headphone jack doesnt put out any sound. how do i fix that?
Is dit een goede vraag?
Score -1
2 opmerkingen
Will it work if you wiggle the headphone jack back and forth while it is plugged in? Does it work when you partially pull it out of the jack?
door
checked for dirt and dust yet?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Assuming you have conditions that old turkey speaks of you will need to replace the headphone jack. There is a guide for that :-) the repair is not an easy one or one for a novice.
Good luck
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
+ I agree Garry, it might help mnmbug if you provide the links in your answer. This way people will know what they are up against :-)
door
Hi Old Turkey, is there a easy way to track the link down from a mobile device? I am usually on my phone when responding (rarely get time on the computer these days). If there is a trick others use I would be happy to use as well. I still have some tricks to learn ;-) I do appreciate the feedback - as I would like my advice to be as helpful as possible. Thank you
door
Good question, lets ask the big bosses at ifixit. Try meta, click on the link on the bottom of this page "Feedback welcome" gets you to meta.
door
Voeg je antwoord toe
mnmbug zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 482
