Ga door naar hoofdinhoud
slide lock will not unlock
my iPod2 is damaged and the right corner screen broken and the back dented slightly on the right corner..I have reset and restored but cannot get the slide lock to unlock..
Is dit een goede vraag?
Score -1
2 opmerkingen
iPod2 meaning iPod Touch 2nd Gen?
door
yes sorry I wasn't specific..
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
You probably need a new screen. Depending upon where the dent is, you may have damaged the component the digitizer plugs into. In that case the repair becomes out of reach for most but can be done by replacing the motherboard flex cable.
In your case spend $15 on a new screen and start there.
Good luck
Was dit antwoord nuttig?
Score 2
It is possible the connector just popped out... check that before ordering a new digitizer.
reset my ipod touch
Voeg je antwoord toe
kelly zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 927
