Ga door naar hoofdinhoud
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
How to fix flickering/shaking screen?
I looked at different threads specifying different screen issues, but I didn’t find the exact one I encounter on mine. The screen is flickering/shaking - not locally, but the whole screen. Sometimes it loses connection entirely, to the point of being frozen. When I connect the laptop to the external display it works perfectly fine.
Is it fixable?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Not good ;-{ Your T-CON got cooked!
Basically, you need a new display assembly. do you have AppleCare+? Otherwise you’ll need to be creative! Before we worry about our display how’s your keyboard? Any issues with it, I assume the answer is yes! Then we have a way to get everything fixed under the Apple Extended warranty problem for the keyboard.
Keyboard Service Program for MacBook, MacBook Air, and MacBook Pro
OK, how? I’m sure if you place your system somewhere where its cool (no cooler than 4.4℃/40℉) I bet you the problem disappears! If thats the case then while the system is cool visit an Apple Store to get your keyboard fixed. Let them discover the screen issue during Q/C I think the you get your system back, it will be fixed as well.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Interesting, thanks for you answer! The laptop actually falls under the keyboard service program, I've had it connected to an external display and never noticed any keyboard issues. I also never encountered any difference in the behavior depending on the temperature, is there a way to 100% confirm it's T-CON issue?
door
@mhaligowski - If you have a good image on the external monitor the internal display is the root issue. Your systems graphics and driver logic within the main logic board are all good! As the external display would not work.
The T-CON board is part of the display. Most systems place it with the LCD panel. Apple of course loves to move things around! Here that moved it to the uppercase. Review this guide MacBook Pro 13" Function Keys 2017 Vervanging van de schermmodule Jump down to Step 28 the part being moved about it the T-CON board. Now jump to this Demontage van de MacBook Pro 13" Function Keys uit eind 2016 Now jump down to Step 18 to see more detail.
Do you tend to run heavy processing jobs? This model tends to run hot as its only has one fan vs the TB model which has two. It's important to keep the fan and cooling fins clear of dust and make sure the vents are not blocked. I also strongly recommend installing a good thermal monitoring app like TG Pro pushing the fan up when you are running hot.
door
So you'll need to help it along ;-} Otherwise you'll need to fork over for a new display 16/17 13" MacBook Pro Fn display assembly somewhere around $400 to $720 depending if you go recycled or new.
door
Voeg je antwoord toe
mhaligowski zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 424
