Ga door naar hoofdinhoud
Second generation Learning Thermostat from Nest Laboratories
20 Vragen Bekijk alle
Why is the new battery not powering the device?
I received my new battery for my nest 2nd gen thermostat from I fix it. After I installed it, I charged it with a USB charger. After several hours of charging, the Nest device won’t turn on. When I plug it into the wall, I get a red blinking light at the top. I know I’m installing the battery correctly because, I was able to install the old one and get it to work. Is there a problem with the device or the battery? Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
your best bet would be to contact customer support about getting a replacement battery. sounds faulty. ifixit is usually good about solving this for you.
good luck
Was dit antwoord nuttig?
Voeg je antwoord toe
Brad Burns zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 42
