Ga door naar hoofdinhoud
Before merging with HP, Compaq manufactured a full range of laptop computers. Now they are manufactured by HP mostly with basic features.
295 Vragen Bekijk alle
Why is the LCD screen dark?
Hello,
I was recently donated a Compaq Presario M2000 and was told the LCD screen is dark. I am thinking that the problem with this is that it needs a new inverter. I also thought that the LCD might need a new bulb. Is there any other problems that could be a possibility with this LCD?
As far as I know, it runs just fine, everything else works on it. Its actually still usable if I hold the screen up to a light that way I can see everything on the LCD.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Patrick, start with the easy stuff first. Change the inverter board. After, that reevaluate. There are some good instructions here and the service manual is available right here.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Patrick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,856
