Ga door naar hoofdinhoud
Following the form of Lenovo's slimmer, smaller Yoga two-in-ones, the Lenovo IdeaPad Flex 5-1570 gives you great performance, using an Intel Core i5-8250U 1.6GHz processor and an integrated Intel UHD Graphics 620 video adapter.
10 Vragen Bekijk alle
My laptop bottom base cover is cracked and needs replacemtn
Where can I get a replacement bottom base cover for my Lenovo Flex 4 Series 2-in-1 Touchscreen Laptop . It’s cracked in multiple places and also disconnecting from the hinges. Is there a supplier that can provide replacement parts?
Thanks
Sridhar
Is dit een goede vraag?
3 opmerkingen
The laptop is 15.6".
door
@srig
What is the full model number of the laptop as shown on the information label on the bottom of the laptop?
door
@jayeff
The model number at the bottom reads:
Ideapad Flex 4 - 1580
80-VE
Thanks
Sri
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @srig ,
The parts list for your model shows that the part number for the base enclosure (bottom cover) is 5CB0L46025 (Click on Select Commodity > Covers (1) to view the part number).
If you search online using the part number only (example only) in the search term of your browser you will get results for suppliers of the part.
To replace the base enclosure you have to nearly completely dis-assemble the laptop. Here’s the hardware maintenance manual that shows how to remove all the necessary parts to do this, which should help.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
@jayeff
Thank you for the links. I used the part number and found the base cover at
https://www.impactcomputers.com/5cb0l460...
Appreciate the assistance.
Thanks
Sri
door
Voeg je antwoord toe
Sri zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 866
