Ga door naar hoofdinhoud
The Asus X553MA-BPD07051 is a laptop designed and made by AsusTek Computer Inc. This laptop, released in 2015, runs Windows 8 and can be upgraded to run Windows 10. It is a good laptop for everyday use.
3 Vragen Bekijk alle
Why my computer is not turning on
I have a laptop that suddenly stopped working no fan but the power light is on so i tried a different charger still. i opened the computer removed the battery made a hard reset still nothing the strange thing is when i put the ac cable the cpu begins to heat up even though nothing else is happening
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @faezajackson ,
Here’s a link to the Asus X553MA repair guide that may help as it appears that the problem is on the motherboard.
The guide details the power on sequence (in both modes, battery and AC) and gives the voltage measurement locations for each step in the power on procedure.
It may come down to having to go through the sequence and find out where it fails to find out what the problem is.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
I will definitely try that
door
Voeg je antwoord toe
Faeza Bakr zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 15
Altijd: 265
