Ga door naar hoofdinhoud
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
Vraag afgerond
Why do the Menu/Play/Pause buttons not respond?
The menu and play/pause buttons are not working on the ipod video I am working on. The clickwheel works fine (meaning it moves the curser to the selected part on the screen). I have opened it to make sure the pads are situated correctly (and they are). I cleaned some gunk off the board by the connectors. Additionally, I lifted the tape and dome to make sure nothing was underneath causing obstruction.
The fastforward and rewind buttons work. All depress and "click". The solder joints seem to be in good order (no visible cracks under 10x magnification).
Is this something that can be repaired, or anything someone has encountered? I am looking for a solution that does not involve logic board replacement.
Thanks for suggestions/comments.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I have seen buttons similar to those go bad. I do not have one here to look at right now, but you should be able to use a meter checking continuity to make sure the buttons are actually working. I have replaced similar buttons on logic boards before such as the ones on a DV9000 logic board for the mouse buttons. if you do replace the buttons I recommend flowing some leaded solder onto the connections before attempting to remove the buttons with a heat pump.
Was dit antwoord nuttig?
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 694
