Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
I am having problem to activate iMessage
I just updated my iPhone to the iOS 5.0. I can not activate the iMessage. It gives me an error message. I restored the phone twice. After restore iMessage activate, however after a while it stop working.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hello,
iMessage only works if the person receiving the texts also has IOS5.
Please insure your recipient has IOS5 and has this service enabled. Many of us are disabling it, due to the delay from when you send it, and when the recipient receives it. Standard text are a lot faster.
Hope this helps,
Xico Solutions
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks for your replay. I already check that. The problem is that I can't active the service in the settings at all.
door
Hey Francisco, it seems like the software needs to be updated. Do you have the latest version of iOS?
If not you should update you phone and see if this works for you. Please see instructions here: http://www.technobezz.com/imessage-not-w...
Score 1
Voeg je antwoord toe
Francisco Ramos zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,222
