Ga door naar hoofdinhoud
Verschenen in oktober 2008 / 2,4, 2,53, 2,66, 2,8 of 2,93 GHz Core 2 Duo-processor
Small dent in battery, problematic?
Hi,
Macbook pro unibody as described. Small dent in battery as per picture below. Does this constitute a potential safety problem, or is it just cosmetic with this small dent size?
Edit: The picture shows the battery, not the case.
Afbeelding
Is dit een goede vraag?
1 Opmerking:
Any inputs most welcome.
door
Voeg een opmerking toe
1 Antwoord
Hi there,
Looks like a rather minor dent. There shouldn’t be any damage to the battery and no need to worry. Although if you want to be sure you can unscrew the bottom of your MacBook to see if there are any dents in the battery. MacBook Pro 13" Unibody mid 2009 Vervanging van de onderste behuizing
Was dit antwoord nuttig?
1 Opmerking:
Hi thanks for your answer. It may not be clear on the picture, but the dent is in the actual battery. The picture shows the bottom side of the battery, not the case. Hence the question. What do you think?
door
Voeg je antwoord toe
Opti zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 27
Altijd: 360
