Ga door naar hoofdinhoud
Model A1051 / 4 of 6 GB harde schijf
87 Vragen Bekijk alle
How do you know if the battery health has been deteriorate
Hi I have an iPod mini 2nd Generation. The battery has been holding quite well, I haven’t seen any battery drain yet but I am a bit worried if it doesn’t hold up since it is still an original battery, especially worried on expanded battery
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
You can check the battery stats of your iPod, iPhone or iPad by installing Coconut Battery on yourMac and Hooking up to a USB port and running it.
https://www.coconut-flavour.com/coconutb...
Was dit antwoord nuttig?
Score 1
It depends on how long have you had this for and how often did you charge and drained the battery. I think when the 2nd gen Mini came out Apple was bragging about the battery which was holding more than double the charge than the 1st gen. I think it is rated for 18 hours audio playback.
Now, since these are quite old device, don’t expect the battery to last that long, but I would imagine it should still hold around 8-10 hours playback, again, depending on the intensity that you have been using your device.
Voeg je antwoord toe
lincolnchia zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 21
Altijd: 398
