Ga door naar hoofdinhoud
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 Vragen Bekijk alle
MacBook Pro battery problem?
I installed my ordered ifixit battery yesterday, but upon checking the health I came across the age of the battery which 10.2 years old with a manufacture date of 3 Jan 2011 using battery health 2 app which I don’t think reliable. I am following the instruction to calibrate, but while discharging from 100% to 0% the battery went from 40% to 7%. This has me worried. Ifixit have said to run the battery for 20 cycles to properly calibrate.
Update (03/03/2021)
its been a few weeks now. I was sent a replacement battery the old battery was at 67% health at the end with 55 cycles on it. I installed the replacement yesterday, I am sorry to the same thing is happening. The battery is calibrated. I am charging it to 100% then when discharging the power levels drop from over 50% to 7%. I think they need to change their supplier.
Update (03/03/2021)
the replacement battery is now has 5 cycles and the battery health is down 10%. I have followed the calibration instructions as before. I am using better battery 2 app to see the status of the battery and usage history details.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
It sounds weird that it says that the battery is so old.
I would recommend you to contact the iFixit support about that and they will help you, here is a link to the support contact information.
iFixit Support
Was dit antwoord nuttig?
Score 1
5 opmerkingen:
The battery info says 3rd January 2011 two times in a row the % dropped from 50% to 7% instantly. I have emailed Ifixit, still waiting for a reply. I have sent screenshot as well. Also the battery health has dropped to 96% in a day with the mAh dropping from 8600 to 8297 mAh.
door
The health of the battery has now dropped to 93% and the max is now 8037 from original max of 8600. I have had no reply for ifixit to resolve this issue yet.
door
@Harry G - did you contact iFixit Support?? I would do that ASAP !!
door
@danj I did. It seems the 10.2 years old is a display error using another app the age comes from 21 dec 2020. But I still have a problem with it fully discharging in matter of 2.5 hours. The battery keeps on dropping from 50% to 7% just in a instant. Ifixit have said to run it for 20 cycles to properly calibrate and if I feel it not working still they will offer a replacement.
door
@Harry G - Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Voeg afbeeldingen toe aan een bestaande vraag
door
looks like I have same problem with my MacBook Pro 15 mid2014. bought on eBay one month ago with 4 cycle count battery, now has 40 after one month usage and battery health dropped from 9000 mah to 8300. i’m using 100% original MagSafe 2 charger directly from apple.com so maybe seller sold me refurbished MacBook with bad battery quality. I’m losing 200mah every week with only browsing use ?
Voeg je antwoord toe
Harry G zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 87
