Ga door naar hoofdinhoud
The TravelStar DJSA-220 is a 2.5-inch form factor hard drive released by IBM around the year 2000. It has a capacity of 20 GB.
What computer does this hard drive go in
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi @jpicking85
That is a PATA HDD.
So it will fit into any PC that has IDE connectors on the motherboard and also a spare 4 pin power cable to connect to the drive.
If inserting in a desktop and not a laptop you will also need a 2.5” to 3.5” caddy so that it can be physically mounted in a drive bay
It is outdated now but you can get IDE HDD to SATA adapters that will allow you to connect to any PC that has the sata connectors.
Here’s a link that may help.
Was dit antwoord nuttig?
Score 1
It will work in any laptop with an IDE interface. Some laptops may have trouble fully addressing it without a 3rd party tool to split the partitions on the drive, mainly 28-bit LBA machines which cap at 128GB.
Score 1
Voeg je antwoord toe
Jonathan picking zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 183
