Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Samsung Galaxy Note II is een smartphone die bekend staat om zijn combinatie van een groot beeldscherm en software die geoptimaliseerd is voor een geïntegreerde, in het toestel opbergbare stylus.
Testing the device without a battery?
I recently got a as-is device lot for a iPod Classic 6th gen but this phone came with it, but no battery (SGH-T889), along with a Galaxy Core Prime I need to replace the LCD digitizer on and make sure the LCD is okay. However, due to the lack of battery with the Note II I cannot test it right now but I don’t see any AMOLED screen cracks. It also looks like the IMEI is clean. Sadly, I lost the battery from the Note II years ago.
That being said, I also have ANOTHER Note II I got years ago that was damaged by being broken in the most embarrassing way, but I have a known good AT&T board I have the unlock code for. My plans for this phone are if I can get it working great I’ll try and unlock it as well, but if I find something is off about it I have the AT&T board I can drop in and then I’ve finally gotten around to rebuilding it.
I have one coming, but is there a way known to work to get around these things demanding a battery to even TURN ON?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
I have tried to get phones on without the battery as well, but I have had no luck. I would suggest just buying the battery and testing it that way. This is true with a lot of phones, they need the battery in order to turn on.
Was dit antwoord nuttig?
2 opmerkingen:
It's not that I don't have one coming - I do. I was hoping I could quickly check the health of the phone and AMOLED panel.
door Deel
@nick As far as I know there is no easy way to do that, so I would wait for your battery to come in.
door Deel
Voeg je antwoord toe
Nick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 550
