Ga door naar hoofdinhoud
A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
216 Vragen Bekijk alle
MacBook Pro 13 2016 light bleed
Just want to share my CRAZY story regarding those 2016 models.
I got it nearly NEW - yes - 2016 but NEW - DriveDX app reports SSD been powered just 72 hours - YES - just 72 hours and MacBook developed “light bleed”
My point is…… it is NOT happening because opening lid more than 40 degree (which I never even done!) It is just……… “TICKING BOMB” - it is just dying because…… it HAS TO die.
Update (02/19/2021)
Here is what I see
Is dit een goede vraag?
5 opmerkingen
Please post a picture so we can see what you are seeing Voeg afbeeldingen toe aan een bestaande vraag
There are a few extended warranties on this system which I would take advantage of. But your time is short!
As an example 13-inch MacBook Pro Display Backlight Service Program
door
I had chat with Apple and they saw it - yes - I will get new screen - and CORRECT - I got time till........ Fall this year.
My point was - MacBook is virtually NEW (used 72 hours) - and display still DIES (I meant - has light bleed)
door
It would have been helpful to have seen the picture.
door
[image|2333138]
Here is what I see.
And I would go to Apple Shop - but……. all of them in UK they are SHOUT……… because Lockdown 2
door
@Bart - Yes, COVID sucks!
At this point there is nothing more we can offer you. Don't forget to score the answer and accept it - Thanks!
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Any ways…. Apple has you covered!
At least you got a freebee! If you hadn’t posted here would you have known of the extended warranty? It would have cost you a bit of coin needlessly!
Update (02/19/2021)
Here’s your issue, it’s called FlexGate! The Design Flaw Behind MacBook Pro’s “Stage Light” Effect and 2018 MacBook Pros Try to Solve Flexgate Without Admitting It Exists
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I've updated main question with photo - thank You Dan
door
Voeg je antwoord toe
Bart zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 152
