Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
BLU TANK II T193 monsterbatterij 30 dagen stand-by Ontworpen door BLU in Miami | Geassembleerd in China www.bluproducts.com
sim card help installing
CAN NOT FIND WHERE TO PUT SIM CARD, AFRAID MIGHT BREAK IT BLU TANK 2 Do I have to unscrew anything after taking back cover off and removing battery kmcsims@juno.com
Update (02/02/2021)
The picture is ideal but I don’t have that, that is why I wondered if the small screws need to be removed to get to another part in the phone. Thank you
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Hi,
The SIM is just slid into the SIM card slot.
Here’s the section of the user manual that describes how to insert the SIM card. Take note of where the beveled edge is on the SIM card so that you know it is in the correct way.
Update (02/02/2021)
Hi,
It looks like the phone has a SIM card tray that just pops out of the side and you lay the card in that. The tray takes two SIM cards (I think)
Here’s and image taken from the ifixit BLU Tank II Batterijvervanging guide, to show where it is.
Looks like there is a small pin hole that is like with most SIM card trays in that you insert a tray ejector tool to pop out the tray.
There should be an image or an outline of the card on the tray which shows the beveled edge and that it has to go face down to connect with the phone
Afbeelding
(click on image to enlarge for better viewing)
Was dit antwoord nuttig?
Voeg je antwoord toe
karen mcsims zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 1,534
