Ga door naar hoofdinhoud
Dit apparaat is een papierversnipperaar die in 2005 door Fellowes, Inc. is geproduceerd. De versnipperaar kan 7 vellen papier tegelijk versnipperen, evenals creditcards, identiteitskaarten en pasjes van dezelfde dikte.
What are the gear part numbers?
The primary and secondary gear teeth are stripped, do you have any idea what the part numbers are? I’ve looked everywhere I can think of. Thanks!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I had a look around and couldn’t find any part numbers for the gears. The best thing you can do is count the teeth, measure the diameter and thickness and check if you can find a similar gear is a specialty shop that sells gears. Do note there are different type of teeth, so also pay attention to the form of those.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
What are the "tenths" that you're referring to?
I've only counted teeth so far (12/50). Once i get the dimensions, do you know of any sites that are set up to search by dimensions?
Thanks!
door
Oops, I meant teeth there. I've seen this website passing by in some other forums https://www.hpcgears.com/ but I think if you know the diameter & amount of teeth you could do a google search with that and get some results to sites that have advanced filtering.
door
Hi, I've helped others reproduce damaged plastic gears that you can't buy anywhere. Please message me and I'll be happy to help you. https://www.ebay.com/usr/krunkz
door
@mrmaster8300 self promotion on here is consider SPAM. Please feel free to add your services to your About page but not in Answers. You can refer from Answers to your About page but not to any outside link that will promote your business. On the about page it is okay to give more details about what it is that you do and your specialty, NEVER IN ANSWERS! and NEVER ON THE GUIDES
door
Voeg je antwoord toe
caleb.peacock zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 14
Altijd: 367
