Ga door naar hoofdinhoud
Uitgekomen op 4 november 2017. Model A1865, A1901. Verkrijgbaar als GSM of CDMA / 64 of 256 GB / Zilver of Space Gray. (Uitgesproken als "iPhone 10".)
Earpiece Not Working But proximity sensor does
I have a problem with my Iphone x. Basically the earpiece is not working but the proximity sensor and face id work normally.
Is there a way to fix the earpiece whithout changing the whole flex cable causing the face id not to work?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
As stated in the earpiece repair guide:
This assembly is paired to your individual iPhone from the factory, so you must transfer it from your old display to your new one during any display replacement.
The flood illuminator forms part of the biometric Face ID security feature, and Face ID functions will fail if the original component is damaged or incorrectly installed. Replacing it with a new part will also cause Face ID to fail, so take extra care not to damage any of these components during this procedure. If damaged, only Apple can restore Face ID function.
So this means if you replace the front sensor/earpiece assembly with the flex cable you’ll lose Face ID. It is possible to replace the speaker alone, but this requires high level of soldering skill as can be seen in this video of NorthridgeFix: https://www.youtube.com/watch?v=qo-tOq8y...
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Oh okay, thanks I'll maybe try it
door
Good luck with the repair! And thanks for accepting my answer :)
door
Voeg je antwoord toe
Nova Class zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 135
