Ga door naar hoofdinhoud
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Vragen Bekijk alle
Touchscreen stops working and forced to connect the flex everytime
Hello,
Like the tittle says, today i turned on my phone and the touchscreen stopped working completely, so i opened the phone, unplugged and plugged the screen flex cables, after that the touchscreen came back to life but suddenly some ghost touches started to happen and again the touchscreen became dead again and im forced to repeat the process all over again with the same results.
Any clues?
Thanks in advance.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Since the touch components are on the screen and not the logic board the most likely cause is either the connector or the screen. Check the connector under some magnification making sure the pins are not pushed into the plastic. If it looks alright it will be a faulty screen.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Daniel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 25
