Ga door naar hoofdinhoud
De Samsung Galaxy S9 kan worden geïdentificeerd aan de hand van het modelnummer: SM-G960XU. Het toestel vormt de negende generatie van de Samsung Galaxy-serie en werd in maart 2018 gelanceerd. Verkrijgbaar in Lilac paars, Midnight zwart en Koraalblauw.
137 Vragen Bekijk alle
If I replace the motherboard, will it fix my charging issue
My phone will not charge, I believe that the device responsible for telling the phone where to draw power is faulty, which I have been told is an issue with the motherboard.
My question is, my phone being a t-mobile device, can I replace my motherboard with an unlocked Verizon board, and not have any trouble?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Before you swap the motherboard, try replacing the charge port if you haven’t already. Just make sure you get the right variant for the port. Otherwise it will say SIM not detected.
If that doesn’t work you should be ok to swap the board for that unlocked version just make sure the model number on the charge port matches otherwise you’ll have the issue I mentioned above. If they don’t match up just transfer the charge port with the board.
Was dit antwoord nuttig?
3 opmerkingen:
so i have had it confirmed by ubreakifix that it is a motherboard issue, now i have discovered that the device is carrier locked, if i buy an unlocked motherboard will that be fine or is it somehow device locked.
door
@thepianodoctor yeah an unlocked motherboard should do just fine. Just make sure you have the corresponding charge port and cameras with said motherboard.
door
how can I make sure that I am buying the right motherboard for my phone
door
Actually I also have a question, my device, just after a year of normal usage started showing battery problem. I replaced it's battery but it didn't helped, I handed it to a repairing shop but that guy was unable to fix it. I think that there must be a leakage somewhere or something like that, and there I want to ask u guys whether changing motherboard will work or not. If anyone knows anything then please tell me.
Voeg je antwoord toe
john Workman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 50
Altijd: 1,206
