Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
iPhone screen working weird
i have iphone 6s and i changed the screen. the screen is perfectly working fine on an other iphone but on this iphone after you hard reset it it works then it stops and when i shine a flashlight on it you see that the backlit doesnt work. after i reset it again the screen works again perfectly fine. then i put a new screen on the same iphone with the problem and it gives the same problem. what can i do?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
did you look very closely at the ribbon cables that connect the screen; both the board side and the ribbon side, check for bent pins.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Mega Dealz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 36
