Ga door naar hoofdinhoud
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
20 Vragen Bekijk alle
camshaft and crankshaft sensor locason
where r thay at on the car
Is dit een goede vraag?
Score 1
1 Opmerking
What engine?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
peoplesmickey Its a bit lengthy to explain and I thought it might be easier if I let you download the Engine, Mechanical part of the manual from here. I attached a few images from the manual for your immediate use. It's number 16 in the last image ;-) Hope this helps. BTW, wondering what you are up to that you need the location for both of them ;-) Good Luck
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
peoplesmickey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,082
