GE GDT695SGJ2BB fills with water but dont spray, wash dishes
my Dishwasher GE GDT695SGJ2BB acts weird, it fills with water but does not start the washing process. The arms do not rotate and the dishwasher sits like that to the end of the cycle. Then it just drains and heats in the end. It drains very well, I can see it in the Garbage Disposals. I found the tech sheet under the dishwasher and followed instructions from there. So, I entered the ERROR MODE. I found out that my HEATED DRY and LOCK LEDS are SOLID. This means that this is a Wash Temperature error. Which is weird. Then I entered SERVICE MODE. I did all 5 tests from the tech sheet. So I found out that I can not pass the Circulation pump test. It seems like this pump does not work. BUT I could pass the DRAIN PUMP test. Now I am confused. I thought that Drain Pump and Circulation Pump - is ONE pump. But anyway, if these are two devices, then I have to replace one of them. Anywhere I should look more, or this Circulation pump is an issue?
Is dit een goede vraag?
1 Opmerking
So this happened again. It is stopped spraying water and wash dishes. I checked the circulation pump and it is very hard to spin the motor. I believe that the pump is bad and I have to replace it.
door kolfild22
