Ga door naar hoofdinhoud
Technische informatie over de Nespresso CitiZ-koffiemachine. Ze zijn verkrijgbaar bij verschillende merken, zoals Krups en DeLonghi.
Where is the block in the machine?
My Nespresso Citiz stopped making coffee. I descaled it according to directions with descaling powder. I removed airlock using YouTube instructions. The water goes through without a capsule. Once I put a capsule in, there seems to be a blockage and the machine only drips a few drops then stops. I’ve been using a stainless steel reusable capsule for several months now with no problem. I made sure holes in the capsule were not blocked and I also tried putting in less coffee in the pod.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
I think I answered my own question. The coffee was ground too fine. I wasted a lot of coffee but I think I finally calibrated my burr grinder to the right setting for espresso. Before I used ground coffee but I just started grinding my own beans.
Was dit antwoord nuttig?
Voeg je antwoord toe
Helen Atkinson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 8
Altijd: 369
