Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Een film- en diascanapparaat van Nikon dat te herkennen is aan het modelnummer LS-40 ED.
Anyone know how to open this up for cleaning?
I have a Coolscan IV slide/negative scanner and would like to clean it. There is gobs of dust on the element. Can't really just get in there with an air can.
There are screws holding the steel shrouding on the back, but I cannot seem to get the plastic front plate off. Not sure if it should pop off, or if there are other connectors.
I would appreciate help here.
Many thanks!
Is dit een goede vraag?
1 Opmerking
If you check on the link I sent you, it says "To get the front faceplate off, use a flat screwdriver to gently pry the tab away from the chassis"
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
jmmx, check on here it should show you how to do it....Good Luck
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
This is great. I guess I will give it a try. I received a quote of $40-90. I am sure it would wind up closer to the high end.
Many thanks!
door Deel
Wow that seems steep. Looks like you could do most of it by yourself. Just take your time and keep it clean ;-) Save some money....
door Deel
Voeg je antwoord toe
jmmx zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 27
Altijd: 2,445
