Ga door naar hoofdinhoud
The MSI GT72 2QE Dominator Pro is an MSI gaming laptop released in 2015. Comes with an Intel i7 processor, Nvidia GTX 980M graphics card, and Windows 8.1 operating system.
pc wont recieve power
i have had this laptop for 5 years and it will work like new for the most part, but for some reason it has started not recieving power, sometimes it can get it, but most of the time it wont get anything at all
MSI gt7 2qe dom pro
Update (01/01/2021)
it could be my battery, it just started up nad charged up fully in 10 minutes
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Try creating a Win 10 battery report to check the status of the battery. Look at design capacity versus full charge capacity
If the laptop is giving no indication that it is being powered by the charger first check that there is +19.5V DC at the output of the charger. If there is, then flex the charger cord at both the charger end and where it enters the plug to ensure that the output is steady. If you don’t have a DMM (digital multimeter) then try a different compatible charger and check if it always works
If the charger is OK then perhaps the DC-In jack may be faulty or loose from the systemboard.
Here’s a video that may help. it shows how to open the laptop so that the DC-In jack can first be checked to see if it is loose and then how to replace it if it was faulty.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Also get the MSI battery calibration tool and calibrate every 3 months...
https://www.msi.com/Landing/dragon-cente...
door
Voeg je antwoord toe
christian Bagger zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 839
