Ga door naar hoofdinhoud
Samsung's flagship phone-with-stylus and the successor to the Note8, released August 2018. Features a 6.4" display and up to 512 GB of onboard storage.
104 Vragen Bekijk alle
Phone wont turn on/charge after cleaning main board
Just recently cleaned corrosion off of the main board that was near where the battery connects and plugged every thing back in. Showed the charging symbol and LED for about 15 seconds and showed a temperature warning for about a minute. Now the phone is refusing to turn on or to even charge for that matter.
Edit: I disconnected the battery and it did it repeated what it did above, only when the battery is disconnected.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Make sure the wireless charging coil is connected and making good contact with the pins on the board. There’s a temperature sensor attached to the coil and if it’s not working or not reading it, the phone will refuse to boot or charge because it’s not getting accurate temperature information.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Jaron Vincent zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 44
