Ga door naar hoofdinhoud
The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
88 Vragen Bekijk alle
Why is there no video?
So my GameCube has no video, but it has sound. Further inspection shows that only the red input is working and not the white and yellow.
i tried switching cables and that didn’t work.
thanks in advanced
Is dit een goede vraag?
2 opmerkingen
Hi,
Have you proved that the the AV input (yellow - video + red & white - left and right audio) on the device (is it a TV?) that the game cube is connected to is working OK, you didn't say? You only said that you changed cables.
Try connecting another device that has an AV output to the device, e.g. a dvd player and check that there is video and audio when using it to determine whether the problem is in the game cube or not.
door
Hi! So I tested the same cables and TV with another GameCube I have, and it works fine.
Thanks!
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi,
Here’s a video that may be of some help with locating the problem.
Also here’s the ifixit Nintendo GameCube Repair guides as well which may help with getting access to the component parts
Was dit antwoord nuttig?
How about check to see if the video connector has a bended pins or damaged pins?
1 Opmerking:
There at no bent or damaged pins
door
Voeg je antwoord toe
David Lank zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 151
Altijd: 6,115
