Ga door naar hoofdinhoud
A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
216 Vragen Bekijk alle
Can you swap ssd in between 2 MacBook Pro?
I have a Macbook pro 2016 (A1708) which is not starting anymore (logic board dead). Can I swap it’s ssd to another A1708 and recover the data from there? Will this work or will I have issues?
If this is not possible, how can I recover data from the ssd? Are there any adaptors ?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You are very lucky! The Fn series share the same SSD drive! As long and you are careful you should be able to transfer the SSD across. Follow The fist part of this guide disconnecting the battery before you remove the SSD! MacBook Pro 13" Function Keys eind 2016 Vervanging van de batterij
Jump to Step 10 in the Demontage van de MacBook Pro 13" Function Keys uit eind 2016 to see how the SSD is removed. Make sure you slide it out without lifting it too much (you may want to loosen the logic board a bit to get more room).
Here’s a bit more on the custom Apple SSD’s The Ultimate Guide to Apple’s Proprietary SSDs Jump down to Gen. 5 section
MacBook Pro 13" Function Keys Late 2016 Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
MacBook Pro 13" Function Keys Late 2016 Batterij Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
1 - 2 hours
Was dit antwoord nuttig?
1 Opmerking:
Thx a lot for the detailed info!
door
Voeg je antwoord toe
Mez882 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 186
