Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Volledige reparatiehandleiding voor de PSP Go, inclusief instructies voor het upgraden van de accu en het repareren van het beeldscherm.
PSP Go - No Power, No Charging
Day before yesterday every time I plug in the charger orange light turns on for little while then it turn it self off, now since yesterday my PSP Go doesn't charge, NO orange light and I can't turn it on.
Any word of advice how can I determine what's causing this problem (USB cable, AC adapter, or PSP itself)?
Is dit een goede vraag?
Score 6
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Gekozen oplossing
hold square triangle start select and home and turn it on good luck:)
Was dit antwoord nuttig?
Score 7
4 opmerkingen:
great thanks really helped ..
door Deel
no it didn`t..
door Deel
I cant believe this worked, after around 9 years of not being able to use my psp go, this helped. PSP GO is like new and i can continue my gaming
door Deel
this trick worked on my psp go that only charged with compatible cables. i tried 2 different original cables and no luck on charging or connecting to pc on usb mode. after the trick works wonders
door Deel
Wolfin2010, check your AC adapter with a multimeter/voltmeter just to make sure it works. Also check your cable and make sure it is not frayed and in good working order. Check the plug on your PSP and make sure it does not have any corrosion or other damage. If all that checks out, I would try a new battery. PSP Go-batterij vervangen after that it is time to reevaluate. If you are really handy, check on here for the fuse location of your go and check your fuses to make sure they are all okay. Hope this will at least get you started. Good Luck
Score 2
1 Opmerking:
Hi I already replaced my battery but am having issues again. Any ideas?
door Deel
Having same problem with my PSP1001 going to try resetting first if that don't work then I will test the charging pin to see if its not making good contact.9 out of 10 times its one of these…..
2019, PSP go hasnt worked since I was a kid (about 10 years ago when I took a trip overseas) and tried this AND IT WORKED. I cant even believe it I'm so excited. Give me your EXACT address so I can come kiss you my good sir
Voeg je antwoord toe
Wolfin2010 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 132
Altijd: 36,571
