Ga door naar hoofdinhoud
The LG G4 was released in the US in early June 2015, as always focusing on high-end specifications and a refined fashion sense that makes it stand out in the premium smartphone market. Each version of the phone will have a different model number based on if it is sold by a carrier or unlocked (US or International). Some LG G4's are known to have bootloop problems.
20 Vragen Bekijk alle
Lg g4 Wifi entegresini nasil degisebilirim
Lg g4 wifi problems. How can i change wifi chip
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
You don’t say what the problem is or what you have tried to do to fix the problem but replacing the WiFi chip seems a bit excessive.
Have you tried disabling the smart network switch to see if this fixes the problem?
Here’s how to do this:
Enable the mobile data connection.
Then go to Menu -> Settings -> Wireless and uncheck the smart network switch option
Your internet connection may not be so stable anymore as it won’t be switching between the WiFi and the mobile network internet connection trying to achieve the most stable connection possible.
Also try wiping the cache partition in case there is corrupted cached data that is affecting the WiFi
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
I did what they said but it didn't improve
door
@Yusuf Sonmez
Please Unaccept my answer as it didn't work for you.
What is the problem with the WiFi , you didn't say?
door
Voeg je antwoord toe
Yusuf Sonmez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 179
