Ga door naar hoofdinhoud
The ASUS ROG series computers are a line of high-end gaming PCs. The G751JT is 17inch offering from ASUS. It was released to compete directly against Dell's Alienware AW17 and MSI's GT series laptops.
3 Vragen Bekijk alle
Why is there white lines going across my screen
Whenever I power on my laptop I see white lines in certain places, even if there is a dark background. I want to know if I need to get my computer cleaned, repaired, or other options.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @amanda34 ,
Things to try to narrow down what is the probable cause of the problem.
a). Start the laptop in safe mode and check if the problem is still there or not. The screen will look different because only generic Windows drivers are loaded and not drivers specific to the hardware in the laptop. This is only to check if it the problem is there.
If it is not there, then it is a video driver problem. Check that you have the latest Asus Win 10 VGA drivers installed.
b). If the problem is still there in safe mode, connect an external monitor to the laptop’s HDMI port and check if the problem is also on its display or not. Even a TV can be used as an external monitor as long as it has HDMI inputs and that you have a compatible HDMI cable to connect the two together. Don’t forget to operate Fn + F8 (both together) to toggle the display between laptop screen only, external display only or both on together.
c). If also showing on the external monitor screen, then there is a motherboard problem
d). If only on the laptop screen, then the laptop would need to be opened and the video cable connection between the motherboard and the LCD panel would need to be inspected at both ends (motherboard and screen) to ensure that it had a secure connection. If it appears to be OK then as a DIY repair all you could do is to temporarily replace the LCD panel to check if it is the cable or the LCD panel.
Here’s a link to a supplier of parts for your model laptop. If you click on the Display checkbox you will find the Asus part numbers for the screens that are compatible with the model. If you then search online using the part number only, you will get results for other suppliers that may suit you better. Usually the part number is printed somewhere on the back of the panel if you wish to verify that you’re getting the correct one.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Amanda zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 60
Altijd: 3,367
