Why wont it turn on and shows error message and wont charge battery?
I bought this camera on ebay and it worked great at first but the camera wont charge the battery, and when i connect it to power, instead of charging it just blinks repeatedly.
Is dit een goede vraag?
3 opmerkingen
Have you checked out the battery? It is possible that you battery does not charge. does it blink a pattern or does it blink continous? Have you checked your power supply to make sure it is charging. Use a multimeter on your battery contacts to see what you get
door oldturkey03
its not the battery because i checked online and when i connected the camera to the outlet power supply it blinks repeatedly for a short while, and that means that there is an error on the camera. how would i get a multimeter and check the battery.
door Christian Quan
Make sure your software for camera driver is up to date, I've had this happen when there was a mismatch with camera/driver
door pollytintop
