Ga door naar hoofdinhoud
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Some special keys do not work
Hello, I have a MacBook Pro from 2012, A1398.
The following keys are no longer working.
  • left shift
  • left ctrl
  • left alt
  • left cmd
  • right shift
  • F1 - F9
On an external keyboard these keys are working.
SMC reset is not possible as the according keys do not work.
Any idea except exchanging the keyboard?
Thank you
Update (11/21/2020)
Thank you Dan.
Actually I replaced the battery yesterday and the problem has started. Could you please describe where the battery should touch the keyboard cable.
For me it seems separated (I have not removed more then the battery so far).
I tried to search for a cabling diagram for the keyboard to see the connections with all the keys which are not working. I removed the keyboard connector and cleaned it (further if I shutdown, most of the time I have to remove the power cable and the battery cable, press the power button and replug the power cable, then the system boots, otherwise not. Afterward I also re-connect the battery cable. For this additional problem I would like do the SCM reset).
BTW - For upper case I currently work with caps lock, or using the keyboard viewer tool - there I also see clearly which keys are working. This beside the workaround with an external keyboard.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
At this point you’ll need to check a few things. The first is strangely the battery! As the battery ages it off gases and like a ballon it expands with limited places to go. Often it presses against the keyboard and the keyboard cable which can damage it. Install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Voeg afbeeldingen toe aan een bestaande vraag
The other issue is liquid damage on the logic board at the keyboard connector area. You’ll need to pop the bottom cover off to inspect that as well as double check the battery if its blistered up MacBook Pro 15" Retina-scherm mid 2012 Vervanging van de onderste behuizing
Sadly, that still doesn’t deal with the elephant in the room the keyboard its self could be damaged either liquid or due to a failed battery. That gets into replacing the keyboard or upper case following this guide MacBook Pro 15" Retina Display Mid 2012 Upper Case Assembly Replacement for either and then if you are up to it undoing the 50+ screws to pull the keyboard out:
Replace an upper case and keyboard compatible with the Mid 2012 to Early 2013 Retina 14" MacBook Pro laptop. Afbeelding
Product
MacBook Pro 15" Retina (Mid 2012-Early 2013) Upper Case Assembly
$89.99
Replace a damaged, dirty, corroded, or malfunctioning keyboard compatible with a model A1398 15" MacBook Pro with Retina display from Mid 2012 to mid 2015. Afbeelding
Product
MacBook Pro 15" Retina (Mid 2012-Mid 2015) Keyboard
$19.99
MacBook Pro 15" Retina Display Mid 2012 Onderste behuizing Afbeelding
Handleiding
Moeilijkheid:
Eenvoudig
5 minutes
MacBook Pro 15" Retina Display Mid 2012 Upper Case Assembly Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
1 - 3 hours
iFixit Afbeelding
Handleiding
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
Was dit antwoord nuttig?
Voeg je antwoord toe
panther zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 96
