Ga door naar hoofdinhoud
Released in June 2020. 10th generation intel device. Available in slate gray and orchid. Model identifier 82AS.
4 Vragen Bekijk alle
What is the repairability of Yoga Duet versus Surface Pro 7?
I’ve known so far that repairability of surface devices are bad with exception of Surface Pro X.
Therefore, it would be amazing if someone can say at least if it’s easier to access Yoga Duet 7 than Surface Pro 7.
This should be a selling point if it’s easy to repair.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Don’t know about either of the laptops, but here’s the hardware maintenance manual for the Lenovo Duet 7 13IML05 taken from this webpage which at least documents how to remove all the components etc which at least makes things a bit easier.
Also the parts link on the support webpage also gives you all the part numbers for the various components so that you can find them easier online by simply searching for the part numbers.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
integratemiguelsantos zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 577
