Ga door naar hoofdinhoud
Uitgebracht op 20 september, de reguliere 2019 iPhone van Apple wordt geleverd met een 6,1" LCD-touchscreen, dubbele camera's en zes beschikbare kleuren. De opvolger van de iPhone XR.
Screen jumping, glitching after installation
Replaced iPhone 11 screen but the screen is jumping and glitches after screen replacement. Had similar issue with the cracked screen so I don’t know if there was a previous issue not related to the screen. Anyone have a similar problem? Thanks
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I can’t say I’ve had this problem before but it could be that the replacement display is also faulty. Did you unplug the battery prior to removing and reconnecting the display? I would leave it turned on for a couple of hours and see if the problem goes away, it could just be static.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Yes, I unplugged the battery. I’ve had a similar issue and agree with you that it could be a faulty screen. I’ll reach out to the ifixit team for help since I purchased it from them
door
Yes either a faulty screen or just some static, try leaving the phone turned on for a while and see if the problems carries on. If the problem continues then it sounds like a faulty digitiser.
door
I’m having this issue rn but the screen works fine when not housed properly in its case jus freely sitting while connecting an everything works like a charm an as soon as I put it in properly it starts not workin to touch at all moving on its own an jus not what it’s supposed to do
door
Voeg je antwoord toe
David Torres zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 25
Altijd: 1,571
