My iPod went through washing machine. Won't play.
Following iFixit directions, I’ve started disassembling it. Previously, when I plugged it into the Air USB port, its contents were readable and replaceable. But when I install new songs/synch, it won’t play. I’m not sure but does not seem to take a charge. New battery? Logic board? Both?
Is dit een goede vraag?
6 opmerkingen
Yeah a good guess would be the battery
Did you open and clean the thing with 99% alcohol
door Tsar_ Bomba
Thanks for your advice! I buried it in rice for 5 days. Have not cleaned it with anything. Not sure how to do it with alcohol. Brush it gently? Soak it? Anyway, 99% is not available here. Only 91%. Please advise further. Much appreciated!
door Chuck Schroeder
Um... brush it. I don’t know if 91% will work but is it high quality? It’s all about preventing accidental links between circuits. 99% alcohol means that there should be less impurities to be left behind, causing unwanted linking and shorting.
door Tsar_ Bomba
Don't know about "quality". It's standard rubbing alcohol from a pharmacy. If you thing it will do more harm than good I'll order from Amazon.
Again, thanks for you advice!
If it’s really value to you, don’t take chances, if it’s not, then 91% will probably work
door Tsar_ Bomba
1 commentaar meer tonen
