Ga door naar hoofdinhoud
The Xterra was introduced in North America in the 2000 model year (1999 calendar year) and marketed using the tagline Everything you need, nothing you don't.
12 Vragen Bekijk alle
Nissan Xterra 2001 V6 3.3L Knock Sensor replacement
Knock Sensor Replacement instructions
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Here’s the 2001 Nissan Xterra Repair Manual (SM1E-1W22U2)
On p.EC-936 in the Contents > Engine Control System section of the manual it shows the location of the knock sensor for your engine type and how to test it but it doesn’t detail how to replace it. I have looked in the other “engine” sections of the manual but the knock sensor is only mentioned in the Engine Control System section, but I may have missed it.
Hopefully this is of some help anyway.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Enrique Rodriguez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 509
