Ga door naar hoofdinhoud
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
Ipad wont turn on but charges
i decided to charge my old ipad 2 to get some files that were in it, but after letting it charge at 15w for hours its still showing the no battery signal on the screen. It shows as charging, so something is happening
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@daniel_svs sounds to be a battery that has been discharged below it’s threshold and is no longer accepting a charge. Replacing the battery should fix this. Identify your iPad and then pick the right model for a guide on how to replace the battery. After that, re-evaluate.
iPad 2
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
actually, I was able to charge it! after probably 7 hours it turned on...
door
Excellent. Glad it worked out for you.
door
Voeg je antwoord toe
Daniel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 63
