Ga door naar hoofdinhoud
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Vragen Bekijk alle
compatibility flex cable trackpad.
Hello everyone, everything good?
I need to change the flex cable for my MacBook Pro 2015 trackpad and I would like to know if the flex cables P/N 821-00184-A is compatible with P/N 821-00721-A
Can someone help me?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Here is the part you need for your system MacBook Pro 13" Retina (Early 2015) Trackpad Cable, Apple P/N 821-00184-A
I love Apples confusion in the way they manage their parts ID’s! Most companies keep the base P/N and then append a version ID. In your case that would to the letter A or other incrementing value.
But No Apple doesn’t do that! They just spin a new part number! So now which is the newest and which is the older version of the part?? Here’s all of the P/N’s for your cable.
923-01376, 923-00518, 821-00721 & 821-00184
Now the roman way would be to start on the left and make each version to the right be the newer (canonical order), Or if you where in China & Japan then the list would be in the reverse! The most left would be the newest! (non-canonical order) So confusing!
And that assumes the list is in the correct order what if its just any which way! The second being the newest or was it the third??
So any one of these should work! But don’t ask me which is the newest version ;-{
MacBook Pro 13" Retina (Early 2015) Trackpad Cable Afbeelding
Product
$9.99
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thank you very much, you explained it very well.
Here in Brazil I hardly find any information about it.
door
@denisales - I spent my Christmas break with a friend who's family had a cattle farm São Paulo years ago when I was in Collage. We spent most of the time at the beaches. Had a great time, that was a long time ago!
door
@denisales looking at the connectors and location (schematic as well) of those, it will be possible to use either number to find the cable
Voeg je antwoord toe
Denis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 119
