Ga door naar hoofdinhoud
The April 2014 update of the 11" MacBook Air packs refreshed dual-core i5 and i7 Haswell processors and slightly increased battery performance.
100 Vragen Bekijk alle
Won´t sleep when close lid, faulty hall effect sensor?
The MacBook running newest MacOS Catalina won´t sleep when i close the screen/lid.
Tried reseting SMC and PRAM, also tried running a magnet along all edges with no effect. Running on original Apple SSD.
Wondering where the hall effect sensor is located on this model? Is it part of the I/O board as I’m suspecting this is faulty and needs replacing?
Could re-installing MacOS Catalina help? If I manually enter sleep and close the lid it´ll sometimes react once closed and wake up, this is the only scenario in which I seemingly am able to get a reaction from the lid sensor.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Apple loves moving things about! This series Hall sensor is located on the main logic board on the back side as you can see here:
Pop the logic board out and inspect it for corrosion MacBook Air 11" Early 2014 Logic Board Replacement if you see anything take a nice sharp picture and post it here for us to see Voeg afbeeldingen toe aan een bestaande vraag
iFixit Afbeelding
Handleiding
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
MacBook Air 11" Early 2014 Logic Board Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
30 minutes - 1 hour
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks for the picture. I’ve found the problem and it’s the transistor(?) that seems to have snapped/fallen off at some point. Can the individual transistor can be bought from somewhere? If not guess i´ll have to find a donor from a model that has the hall sensor on it’s IO board as I´m guessing it’s the same transistor type on different year models.
door
@wackster - Apple hasn't altered the design over the years so I do think you can salvage the Hall sensor from another board.
door
Voeg je antwoord toe
Marik zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 245
