Ga door naar hoofdinhoud
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
interface port on iPod
My friend leaves his ipod classic plugged into his stereo in his truck at all times. It has been bumped a few times and the cable no longer makes a good connection all the time. Is there a way to reinforce the port on the logic port so it will not fail?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If the cable is loose at the bottom of the iPod, the dock connector, then there is really not a lot that you can do. The little spring pins may just have worn out. I would try a new cable and see if that makes better contact. The only way to fix the dock connector is by replacing the logic board. Not a terribly expensive or difficult undertaking.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Matt Shirey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 520
