Ga door naar hoofdinhoud
A repair page for the Kindle Fire HD 10 7th Generation Tablet/E-Reader by Amazon.
14 Vragen Bekijk alle
Replacing ribbon flex connector
I am trying to replace a motherboard ribbon connector as circled in the image on a amazon fire 10 where the flex ribbon cable slides into that the previous owner messed up. Is there a way to determine the number of contacts and pitch of the plastic connector or an easy way to determine the exact replacement connector I need to buy? Don’t know if it helps at all but on the flex cable itself there is a number 1 written on one corner and number 51 written on the other corner which is also written beside the connector as you can see.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@ntec those numbers are the position of the pins. Number 1 on the connector has to correspond with number 1 on the cable. It is not useful to find a replacement. Since there are no schematics available you would really have to do some tough searches at places like mouser.com digikey.com for something like this to see if you can find a match.
Was dit antwoord nuttig?
Voeg je antwoord toe
John Nguyen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 129
