Ga door naar hoofdinhoud
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 Vragen Bekijk alle
Plan to fix overheating GPU in iMac: thermal pad or thermal paste?
Late 2014 2806 5k 27” iMac - I’m having the GPU spikes come and go depending upon application, flirting with 105ºC here and there.
I am using TG Pro to manage the fan boosting but it seems best fix longer term is to crack this puppy open and do a thorough cleaning internally and to address the somewhat known issue of poor thermal paste breakdown on these models.
I also was weighing the pros n’ cons of swapping the blade out with a OEM one from eBay and putting in a good capacity, zippy HDD.
My research has educated me on the extreme tediousness and propensity to crack the display with this endeavor as well as needing / not needing the OWC thermal sensor if installing a SSD. Anecdotes vary on this, but I figure why not add?
My eyeballs are spinning I’ve been going all over the place researching options. The advice I’m looking for is re: thermal paste replacement.
Dan the Lobster Man seems super helpful in his replies to people in search on this site and I’ve learned alot from his advice. One thing that stuck out was the mention of a thicker compound Apple used on the thermal off-loading during the initial build on these models. This brings me to a divide: 1) get more of this gunk which I think is similar to : K5 PRO viscous thermal paste  (5.3 W/mK) 2) hope someone with the same model can *confirm* the spacing gap between the GPU / CPU and heatsink so I can have a thermal pad ready to go. Looking at Thermal Grizzly minus pads 8 for this (8.0 W/mK). -or- 3) just go with thermal paste if the components are close enough: also leaning towards Thermal Grizzly Kryonaut Extreme (14.2 W/mk) or regular Kryonaut (12.5 W/mk)- advice between these 2 would be welcome also.
Thanks y’all
Update (11/23/2020)
Hi Dan and future answer seekers - update...
My Sunday was an iMac cleaning arena and upgrade session. I split the Fusion, swapped the HDD for a SSD, replaced RAM to be matching pairs (I had purchased used with a weird mix o' RAM) and had a fistful of cotton swabs, hi octane electronic alchohol, and a shop vac.
It was a lengthy process, but I was very much triple-checking every move before proceeding. I followed a mix of the Heat Sink Replacement guide here on iFixit and also the HDD upgrade video over on OWC.
To any that are planing such an endeavor: I didn't find a service wedge would've been handy. I just used a microfiber and laid the iMac on its back on a clean surface, my desk, this let me rotate to sections as I needed to address them and not worry about screws falling down into the air intake lip. And reading glasses, and a articulating desk lamp. And needle nose pliers, needle nose vice grips, an exacto knife, 3M double sided sticky tape - automotive grade, electrical tape, calipers, soft fan art brush (to knock dust off while vacuuming), in addition to the regular Mac torx's, suctions, pizza cutter, etc.
About a mouse worth's of gunk stuck in the fins of the exhaust and general dust and particulates abound. I disassembled the fan to wipe down the shell interior and really go at it on the magnetized fan component (grody).
Then I came to the sancta sanctorum of the heatsink and it's mounting to the logic board and the GPU / CPU elements. Dry, cracked white paste. Thoroughly cleaned with mix of spudger, toothpick, cotton swabs, alchohol.
Used the Gelid pads, even though I also got some Kryonaut paste. But this was a tough part I hovered on for some time. The way the heatsink is designed, the CPU and GPU enters a somewhat recessed indentation of the heat sink so using the feeler gauge I purchased was a no-go. I could use the gauge on the VRAM as that was on the perimeter of the GPU heatsink area. I also did not understand how I could measure using card stock or any thing really.
Now that I am relaying this it occurs to me, I could have taken some modeling clay and made a little ball, place one on the CPU, one on the GPU, then dry fit - in which case when I then released the clay would be at a certain thickness, smushed to something that would give me info to run on. Oh well, Monday morning QB.
Ended up using 1mm on CPU, 1.5mm (1+0.5) on GPU and 2mm (1+1) on VRAM for my Late 2014 5K iMac. I came to these thicknesses by being able to see the VRAM gap and dry fit some filmed pads, but also starting with the 1mm on the CPU / GPU removing the film so the pad was ready, slight clayish 'tack'. Then I dry fit and then removed. The CPU came up, stuck to the pad on the heatsink while the GPU only had a faint smudge of the pad's criss-cross pattern on it, like a print. This told me the CPU pad was flush enough and the GPU needed a little height, so the 1mm for CPU, 1.5mm for GPU.
Going back is always quicker, so sealing it up went okay now I am on my first day of replacing software bits and seeing how the Mac is responding. Upgrade wise everything is going swell. Heat-wise, no so much. I've been opening windows, downloading Creative Cloud apps, setting app preferences, etc and have seen my TG Pro kick on several times and CPU's have spiked to above 80ºC several times, highest being 98º on a Core and 96º on CPU PECI and 69º on CPU Proximity. GPU Core highest 83º. I know this is just one day so far, but I expected lower operating temps doing the seemingly light things I've been doing.
*Also, when reassembling I put the new screen adhesive in place, but left the protective film on one side on so I could piece the screen back held with 9 sections of painter's tape in order to boot before sealing which was good b/c I had the temp sensor from OWC I put on the new SSD too high in the chasis adhered with the 3M tape. So I was able to see it not allowing the screen to be flush at the top of the Mac and easily correct.
Gross Build up…
Keeping screws organized…
Back of display, worrisome streaks
OG Apple Paste on GPU/VRAM
Is dit een goede vraag?
4 opmerkingen:
@magneticarrow - You didn't use thermal pads on the CPU or GPU chips did you?? You need paste on them. The gage was to only measure the gap on the GPU VRAM chips to the heat sink as they are the ones that get the pads (the last image in your update where the white gapping paste was).
door
Yikes. Yes I did indeed. They are rated 15 W/mK. I didn't distinguish the recommendation for thermal pads as only on the VRAM not the GPU / CPU. https://gelidsolutions.com/thermal-solut...
Is this an 'Oh Cripes' disassemble and paste pronto issue? Well I feel silly now.
door
Sorry, you've got to go back in to fix this ASAP!
door
Ok, I went back in (much easier second time around) an put new screen adhesive on order, just using gaff tape atm. Replaced the VRAM 1mm w.1mm pads and used the Thermal Grizzly paste on the CPU / GPU. Reassembled and, Mac no-starty.
After panic and nausea set in, I went back and re-re-disassembled down to the GPU/CPU to reseat everything, re-re-reassembled (I'm getting good at this now) the Mac still not booting up.
More nausea, took a break for dinner read some stuff online and decided to try to reseat the RAM. This got me 3 beeps. I've been experimenting with the slots and my RAM and have found that if I have anything in slot 1 or 2, no bueno - but if only RAM in 3 and 4, then I can boot at least. Prior to this all 4 were working.
I am unsure how to proceed from here.
door
Voeg een opmerking toe
2 Antwoorden
Happy you’ve been following my answers ;-}
Over the years I’ve used many different TIM products. I’ve come to the conclusion a mid to high end product like Thermal Grizzly is more than enough for a pro’s system, and the mid level products are just fine for most people.
The bigger issue is the heat sinks ability to absorb the heat fast enough and the heat pipes to transfer the heat and lastly the fins/fan to dump the heat out.
A simple mind model often helps here. Think of a series of buckets each one has a hole in the bottom filling the next lower one. Each bucket is the different element of the heats path. So as you fill one bucket the water fills it and slowly exits out the bottom hole. So as long as the water is able to exit at equal or faster than what you fill the bucket the water (heat) is transferred to the next. But! Let’s say the CPU is dumping heat faster than what the first bucket can accept without over flowing the lip of the bucket then the system has failed. Or, in truth any of the buckets in the path,. as the heat really can’t spill over the lips edge here it just prevents more heat to move! Thus, overheating the CPU and/or GPU.
So while getting the best TIM solution is important you maybe over focusing on it. Making sure the system is dusted out fully every few years is the first thing I would focus on. Cleaning the fan blades and fin areas being the most important area.
While Apple didn’t use the best TIM in their systems its not as bad as people think! For most people the quality of the TIM Apple used is just fine (needing replacing in 3~4 years). An advanced amateur or pro’s system would likely need better TIM as the processing load is so much higher.
The fact you are using TG Pro gives you a better view of things. But, how you use it is also important! I would graph out over a period of time the thermals, are you seeing an uptick? Are you doing more on your system?
After you clean your system and refreshing your TIM take note of what you see over a period of time was the change significant? If you don’t see a down tick then you may have a bad heat sink assembly. Basically, the liquid coolant in the heat pipes has leaked out so it’s less effective.
As to using gapping paste Vs a heat pad on the VRAM chips.
I always go to the pad! It’s just more effective and you can be sure you’ve gotten the needed surface area contact.
As to the needed thickness Apple has used a few different VRAM suppliers which have slightly different thicknesses of the RAM package. I gave up trying to measure the gap expecting it would be the same across all of the same boards.
Best to use a feeler gage or a bunch of card stock strips with a measuring caliper and dry fit the heat sink using either method to measure. I find the .5mm and 1.0 mm is whats needed on most of the newer systems. Given the price is so low its just smarter to get both upfront.
Was dit antwoord nuttig?
1 Opmerking:
Hi Dan, thanks for the reply and imagery (dear ‘Liza :).
It makes me wonder if there is a market for better 3rd party heat sinks - like a copper enclosure to the liquid (Shows what I know, I had no idea there even was liquid in the iMac heatsinks).
Yes, total as can be cleaning while I’m in there. Since your post, I started logging TM Pro as suggested and can compare after the GPU reseating.
Also as suggested, got a feeler gauge, and the 1.0 + .5 thickness pads, but opted on GELID. I went too deep into the woods and got some FujiPoly as well.
Thanks for the sugs, I’ll update when able.
Also: rethinking the internal HDD / blade business. Financially, it seems better in the long run to look on some external storage expansion, Thunderbolt-wise and come up with a TM back up for all my external drives as well - that’s a lot of TB.
Thx!
door
I did thermal paste replacement for CPU & GPU with " Noctua NT-H2. Which seems be doing great. And, the thermal pad "ARCTIC TP-3 / 1.5mm on the VRam "
The System works fine till i start using " Youtube " only this one " Gpu 0 Diode " over heating like crazy and goes up to 109°C / 228.22°F" and as soon as i pause the video it drops quickly down. to normal temperature. While browsing i do not have any issues its completely normal temps. But is only this " Gpu 0 Diode " that does this.
When watching youtube
When just browsing
Voeg je antwoord toe
Ryan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 32
Altijd: 2,159
